Align 3g system and raptor 50
  • Align 3g system and raptor 50
    Hi
    Will the align 3g system work on a Raptor 50 with a RJX flaybarless head
    Regards Paul
    Hi Paul.
    The short answer is yes mate, it should and has worked all ok for others who have installed a 3G in a Raptor.
    What happens is the 3G learns its swashplate type during initial setup in DIR mode, so it knows whether its controlling an mCCPM or eCCPM machine. The Raptor is a mechanical collective cyclic pitch mixing model.
    Ian Contessa
    Coolice Power Supplies
      You may need a quick uk swash plate, others may have overcome the need for this.........
        HI
        Do you mean an all metal swashplate, I have one on my raptor but i dont know if it is quick uk
          mccpm only seems to work with align 3g v2.1 and not on v3.
          The version 3.0 software does not appear to recognize the mechanical arrangement.
          Trex700n
          Trex700E FBL
          Trex450pro
          velocity50
          velocity 90 / Beastx
          JR 11X
          member of the widnesflyers
