Spektrum RX with 3G
  • Spektrum RX with 3G
    Have been reading that some Spektrum receivers are not compatable with 3G system as the 3G system initates faster than the reciever and therefore does not set properly. Can anyone recommend a Spektrum reciever for my T-TREX 600 3G LE.
    I have a Spektrum AR9000 rx in my 700 and running 3g and not had this problem, not heard of this problem either,
    MK HELI CLUB WEB SITE
      I've had a similar problem with a basic CSM gyro in my old Morley Bell 47. At initial switch on, its a 50/50 chance whether it centres properly or not. However, if you then switch the receiver off and on again, it centres correctly - but the receiver blinks because it thinks its had a power outage!
      Similar gyro on a PPM UHF set initialises without problems - but PPM sets initialise VERY quickly!
        Hey.
        I concur, Spektrum receivers are fine with the Align 3G, I'm running 6200's to JR Spektrum 1221's with no problems.
        Only thing I can say is make sure your failsafes are set correctly.
        Ian Contessa
        Coolice Power Supplies
