Align 3G Sensor Enhancements
  • Align 3G Sensor Enhancements
    There is an interesting thread developing over on HF relating to some successful user modifications for 3G sensors.
    Modifying 3G for better performance - HeliFreak
    I am very happy with my two 3G systems but following these very positive reports am interested try it myself.
    I hope this is helpful input
    TRex 500 ESP VBar
    Flybarless is more
    Very interesting thread for sure..
    Will look into this
    ANdy - CDMFC
    Align 550 Beast X
    Proud owner of 3 x E.G.S.
      All Done.. Now just waiting for it to dry now
      ..Hopefully get it tested on the 450 sport in the next day, and fingers crossed for some good results.
      ANdy - CDMFC
      Align 550 Beast X
        Great thread and good reading.
          definitely going to try this - that nervous thing is what put me off my 3g!
            Oh Well.... First test flight did not go quite to plan
            Upped the gain from 70 t0 80 on the cyclics for first test. Stability and piro was very good.. and did seem to be a definite improvement, BUT... forgot I swapped out the tail servo for another one, and it needed to be set up at the field...
            Well, tail kicked out when I started to throw it around abit, and was too close to the ground to do anything.
            Needs new spindle, main shaft, boom, and added another scar to the canopy..
            Will get it flying again for tomorrow, and will hopefully have some better reports. Initial findings though, is that it does seem to hold better in the hover and seems to be alot more locked in. Will know more tomorrow hopefully
            ANdy - CDMFC
            Align 550 Beast X
              Very interesting
              great find might have a go
              cheaper then a beast X
              Cheers Paul
              Citizen #42
                Or just buy something that actually works like a VBar to start with
                Phil
                  Agreed!
                  You cant beat it imo.
                  x 3
                    Far too much faffing trying to make something of dubious quality work IMHO, just get a VBar Or even a BeastX if you are a bit financially challenged
                    Phil
                      Bit like faffing about whith central heating controls rather than paying for the job to be done properly, Although I suppose if you are a bit financially challenged
                      Gaza07
                      Trex 500esp 6s Beast-X V3
                      Trex 600esp 12s Beast-X V3
                      A few Multi Rotors
                        Now sorted
                        Central Heating is a bit of a suck it and see/grey area.
                        FBL is more buy once and forget or **** around with a half arsed product for ages then buy the best tool for the job
                        Phil
                          ...This thread also gives some hope for the 780 gyro I've had sitting on my bench that just wagged whatever i did..
                          PGK
                            If I have trouble with this 3G, I'll get a plumber to have a look then
                            __________________________________________
                            Dave
                            T-Rex 600E - BeastX -
                            T-Rex 550E - BeastX
                            T-Rex 450 PRO - BeastX -
                            T-Rex 250 - BeastX -
                            DX8
                              Got a couple of V Bars and they are great.
                              My 3G needs to be better so I may just give this mod a go.
                              Just waiting a bit longer for feedback.
                              Blade mCPX - now Version 2
