700 fbl head
  • 700 fbl head
    any ideas where i can buy JUST a fbl head for my 700??
    Skyline models
    T-rex700 flybarless Beastx
    T-rex600 flybarless Beastx
    Outrage Velocity 50 Flybarless Beastx
    Ely-q Vision 90 flybarless Beastx
    Trex 450
    Futaba 10cg
      southwesthelis
      tell them I sent you
      Cheers Paul
      Citizen #42
        Originally posted by Geek View Post
        southwesthelis
        they do just the head..no electrics?
          Mod your FB head by buying the bits from FL. (or Midland, or anyone else who stocks the bits!!)
          Henseleit TDR V-Bar x2
          SAB Goblin 700 V-Bar
          T-Rex 700e DFC V-Bar
          Synergy N7 V-Bar OS105 HZ-R
          Synergy E7se V-Bar
          Synergy N5c FBL V-Bar
          Gaui NX7 V-Bar YS91 Tareq SRX
          T-Rex 550 E FBL V-Bar
          Gaui NX4 V-Bar
            they would build one from parts I bet
            no harm in calling
            Cheers Paul
            Citizen #42
              i am quite funny when it comes to these things..i will only settle for the correct set up.. i would never be happy with make do.
                just buy the parts and build it your self its gonna cost a hundred quid odd i reckon all the normal stockests do the parts and as other have been mentioned im gonna say goto align trex.co.uk raj will do you a good deal
                  yea just worked it out ..just over 100 quid.
                    Fair point, but as far as I know, and i'm sure someone will chime in to correct me, but the head block, feathering shaft, dampers are the same, therefor you just need the blade grips (arms are longer) long balls,swash driver, and swash to blade grip links.
                    Synergy E7se V-Bar
                    Gaui NX4 V-Bar
                      yer they all seem to work out close to the hundred quid mark (the align heads that is) i need to do my 450 pro then i have a full set if you count i have the 500 fbl and sold it
                        Concept do a adk head conversion for £60 which is very nice.
                        In silver and black
                        http://www.conceptcopters.com/store/...id_product=582
                          Not sure Rob.. the main block seems chunkier and longer.. I got the main block aswell when I converted mine.
                          i dont think you can just buy the head anywhere apart from far east.
                          Bits you need to get are
                          Fast Lad Performance - Housing
                          Fast Lad Performance - Grips
                          Fast Lad Performance - Mixing base
                          Fast Lad Performance - Pitch gauge
                          Fast Lad Performance - Linkage balls (need short ones for swash!! long ones already on arms!)
                          Fast Lad Performance - Linkages
                          Totals £101.10 exc p&P
                          Keep feathering shaft, dampers (but new ones in arms kit), main shaft, swashplate
                          Eddie
                          Velocity 90 FBL BeastX V3
                          Trex 600 LE FBL BeastX V3
                          Trex 500 EFL Pro BeastX V3
                          Fusion 50 FBL
                          VBar
                          All powered by a DX8
                            http://www.helifreak.com/showthread.php?t=240305
                            Got a ADK head on this 700.
                              I've got a FBL head for sale It's a sliver 3G one
