Does anyone in simple terms know what each of the Aile & Elev parameter settings do on the 3G software as Im struggling abit to understand them. Problem is my 250 seems to lift off okay but as you start to fly she tends to go into a wobble so I could do with knowing best setting to use for this.
JimButDimButThick!!!
Last edited by tourerjim; 30-06-2010, 10:00 PM.Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
- Flickr Through My Pictures.
Tags: None
You probably want to start off tweaking the gain pots on the unit itself first.
If it's wobbling, turn the relevant pot anti-clockwise, about 1 hour of a clockface, and try again. By relevant, i mean to remove wobble on aileron, reduce the aileron gain pot, same if it's elevator.
Make sure your blades aren't too tight too. Use the "hang" test - fold the blades out straight and inline with the boom, then hold the heli on it's side. the blades should just hold their own weight and when you move the heli sharply down and stop in about 2 to 3 inches of movement, the blades should drop.
it could be more than this, but that's where I suggest starting and see how you get on
RobTeam Align, Midland Helicopters, Optifuel, Cyclone Blades, Scorpion Motors, Thunder Power, Savox Servos, JR Propo
| 3D Championship
I've adjusted both gains on the controller but which ever way I turn them the heli still goes into a wobble which makes me think it has to be one of the parameter adjustments in software setup but which one?Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
Apologies Jim but I've not yet played with the software so I'm not in a position to advise you properly.
I hope someone else can though!
| 3D Championship
Im loving her now after getting the info from here 3G software setup...... - HeliFreak done two lipo's with no probs so now looking forward to weekend when I cando some more 3D'ing with her.Last edited by tourerjim; 02-07-2010, 02:16 PM.Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
