Can anyone help me out until I receive a replacement spare part (which might be a couple of weeks)???
The long sensor to control unit cable on my 3GFBL system is defective - one of the connector pins will not stay in place and is pushing back when the cable is inserted. I have temporarily used the short cable for now to setup but I need the longer cable so that everything can go into its proper location on my 700.
Does anyone have a long cable that they aren't using on their install that they would be willing to loan me until my spare arrives - then I will return you the new spare part?
Also, I could swap my short lead for your long lead if you do not require it - then you'll have a spare
Any help, much appreciated folks.
Dan.
Dan.
i Bent the pin straight and refitted it and it seams fine but don't want to let my other lead go just in case,try bending the pin up slightly and refitting it.
