3GX changing from a Spektrum bind to Futaba
    Buy yourself a second hand ipad or ipod touch from ebay and install the iplayer app for Cbeebies. Saved my sanity !
    :-) Boss had iPad. iPhone too small. Gotta get another iPad :-)
    Gaui R5 + 14S + Tribunus 200 + Scorpion 4530/540 + Bavarian Demon Axon
    Gaui X3L + Bavarian Demon 3SX
    Jeti DS-16, Citizen 625
    iMac + AccuRC =
    Member of East Fortune Aeromodellers
    Jeti Sensors and Apps: https://github.com/AlCormack
      Ian - tried the rebind to Futaba 617 and its still not playing ball, I've ended up pulling this unit off the heli and sticking the one from another machine on, using all connections that failed with the non working 3GX the other unit work perfectly...
      Just test hovered in the garden in 20 MPH winds rock solid.
      I'll take the one not playing ball to a pal's house in the week and see if we get any joy binding with Spektrum Sat's as the previous owner used.
      I'll let you know the outcome...
      Thanks for all the suggestions in the meantime
      Steve
        Right been over to a friends after work who flies with a DX8, first off we plugged two Spektrum Sat's directly into the 3GX along with a bind plug and powered the system up. Turned on the DX8 and bound to the 3GX - It booted! We powered everything off and rebooted the radio and then the 3GX a link was made and both the gyro and gov lights lite up on the 3GX. Plugged in a servo and it moved according to stick inputs from the DX8. I'd taken my laptop with me so we linked up the 3GX to the Align software, parameters could be changed exported and saved. I then updated the firmware from 3.0 to 3.1 once again the 3GX booted following the firmware update. We then removed Spektrum Sat's and wired up my Futaba 617 receiver and booted the system - the receiver linked to my 10C as it had done in the past and unfortunately that was as far as it went.... So tried rebooting it a couple of times and it still failed. We then tried switching back to an external Spektrum receiver and had the very same issue as we did with the Futaba unit, power gets through the 3GX system and a bind is made but no lights on the 3GX.... Finally we plugged both Spektrum Sats back into the 3GX and its boots up normally...... Help!!!!
          I suspect one of the two sockets that the patch leads plug into has a problem. I tried again with one of mine and as long as all patch leads were connected it would bind and start. We know you are plugging it in correctly. So the bad port is most likely in my view. Will wait for Ian if he has any other thoughts.
          iMac + AccuRC =
            Are you powering the 3gx & receiver.?
            • Flickr Through My Pictures.
              I have had this and the only way that I could get it to work was with 2 spektrum saterlite receivers . tried for ages to get it too work with receiver but no joy .
              CJS
                Only powering the 3GX via the battery in port, then using the power out from the 3GX to power the receiver...
                  CJS
                  Power is next to the bind port on 3gx, you should have with the 3gx set of leads that allows you to power both 3gx & receiver
                    Hey Buddy.
                    Oh a strange one that for sure.
                    You don't have a seperate Spektrum receiver you can try instead of the sats? So that the setup is the same as you're trying to achieve with the Futaba gear but only using Spektrum.
                    It shouldn't make a difference, but I'm trying to maybe work out what is going wrong.
                    Ian Contessa
                    Coolice Power Supplies
                    • #25
                      Evening Ian,
                      We did have a separate Spektrum receiver that have the same results as the Futaba unit.
                      • #26
                        Evening Ian,
                        Is one of the cables (from 3GX to RX) faulty perhaps? Or as somebody posted previously - perhaps the ports in the 3GX.
                        • #27
                          Hi Tom,
                          It's specific to this particular 3GX unit I have another that I can plug in using the same cables, receiver and power sources that work just fine.
                          Interesting to read some else has had a 3GX only work when Sats are plugged directly into the unit.
                          • #28
                            Yes I know but as the thread states could not get it too work with a receiver . I have 2, 600 1 with a receiver and the 1 without just couldnt get the 2nd one too work CJS
                            • #29
                              Seajayess,
                              Quick question your 3GX that only works via sat's was that brand new or second user?
                              • #30
                                No it was new came in the 600 dfc pro kit. In some ways its better than having a receiver as my other 600 that has a receiver some times takes 4 or 5 attempts to connect properly .
