Ok - I have gone through all the settings following various you tube videos and guides on here.
In DIR I set the swash mix to around 40% in my aurora 9, gives me +8/-8 pitch on the aileron and +12/-12 on the pitch rage. Elevator mix is set to 40% and pitch at 47% to get the travel range I want.
I then go through the 3gx settings but when the unit re-sets I get something like +12/-12 on the aileron, elevator seems quite extreme travel as well. Its not binding so thats not an issue but as a novice it does look like its going to be difficult to control.
Am I missing something?
I set up the tail ok, put the pots to 12 o'clock and went through each stage carefully, about 5 times now with the same result...anyone help?
I havent got round to the governor yet but thats my next challenge.
