3GX settings for TREX 500 DFC
  • 3GX settings for TREX 500 DFC
    Could somebody please post their settings, for an align 500 with a DFC head, so that I can copy them over to my 3GX. At the moment i'm flying nose in, circuits, lazy 8's and general hovering. I'm looking to go scale once I perfect these manovers, so settings for this type of flying would be ideal.
    Mick
    I have a copy, don't have time till late eve but will sort it out then.
    • Flickr Through My Pictures.
      I have a 450 and 550 and use same settings on both. Took stock default 2.1 settings and reduced roll and flip rate 5 points and have the cyclic pitch expo setting at 2. With no expo in tx. Also both pots on unit are at 1 o'clock.
      Works great for sports flying with the odd flip or roll when feeling brave!
      Gaui R5 + 14S + Tribunus 200 + Scorpion 4530/540 + Bavarian Demon Axon
      Gaui X3L + Bavarian Demon 3SX
      Jeti DS-16, Citizen 625
      iMac + AccuRC =
      Member of East Fortune Aeromodellers
      Jeti Sensors and Apps: https://github.com/AlCormack
        Hey.
        Here are some of my 3GX V2.1 settings files you can try out on the 500. None of them are not set too lively, with the 450 ones being setup calmer still for a relative beginner. I would suggest trying either the 450 or 550 ones first.
        These will give you a good base from which to make any changes to tailor the models feel to your own liking.
        Ian Contessa
        Coolice Power Supplies
          Thanks Coolice (and others) your settings worked really well, particularly the 450 and 550 ones.
            Hey.
            You're very welcome buddy, glad you've got on well with them.
            Ian Contessa
