3gx and DSX9 question
  • 3gx and DSX9 question
    Hi,
    Having problems getting my 3gx to swap from head hold to normal mode I have 2 satallites in the 3gx, and have aux 2 set to aux 2 sw, but this does not work , any suggestions please ?
    aux2 isnt that for governor try on left hand side opposite gyro 3 position switch if i remember correctly
    Santander Factory Team
    Proud wearer of 5 x EGS
      The govenor seems to operate on the gear switch. Your correct the aux2 , seems to be a 3 pos switch LH side , but does not change the 3gx system normal to rate, obviously I am being incompente somewhere!
        ive got DSX9 & 3 heli's with 3GS's & no probs setting HH so cant think where your going wrong, when the aux 2 switch is off 3GX shows green for HH when you flick switch once or twice should show red on 3rd possistion (rate mode).
        • Flickr Through My Pictures.
          HH is aux 2 switch (left) & gov is gear switch (right)
            try putting pos 0 - fig pos 1 40 pos 2 60 see what does, hopefully should get different colours
              so in the device setting aux2 is set to aux2 sw GYR, is this correct?
                Your best bet is to reset your tx then turn off all cyclic & pitch trims then setup without changing channel assignments
                  thanks for your help will have another go tomorrow, when I am more awake!
                    What heli is it on or better still pm & i give you my tx setup
