Well I finally got my new bearings today for the 450 so thought I would try out the new 2.1 update. As soon as I took off the cyclic response was extreme to say the least. I could not control the heli and when ever I tried to hover it would hunt around on the cyclic tipping forward or to the right. Then just as I got it down over it went and bang!
After checking through all the settings I could not find anything wrong with the 3GX setup. I had 30% expo in the transmitter and the roll rates reduced to 30 in the 3GX software. I rebound and went through the DIR prior to flight and checked all servo responses too.
I'm baffled at this and its going to cost £50 to repair. Blades, boom, front TT gears, head, bearings, feathering shaft and main bearings too start with
Anyone else had similar issues?
Rich
Rich
It would be good to compare a few different setups. I will PM you.
