My run through of the align 3gx setup
    Hi Align 3GX Manual which comes with the Trex600EFL Pro does not mention about Flight Mode Settings. Is this an optional to enhance your flying or is this a must, part of the set up. I am new to this FBL and 3GX. Thanks. Htin
    Raptor XC50 FBL RL53,Raptor 50V2 with OS 50, Raptor Titan 50 with OS 50, Raptor Titan SE with RL56. MD500 Innovator. Vario Benze Trainer with Zenoah 23 cc, Vario Schweitzer Petrol 23 cc with 3 bladed scale rotor head. Vario Kobold with Webra 60. Vario BO105 with 4 bladed scale rotor head,Rossi 65. Hirobo 50 Vertol Tandem OS 50 .Hirobo Bell222,OS 60. TREX 700 LE,TREX 600 PRO EFL & TREX 600 Nitro LE. TREX 550EFL & TREX 500 ESP. http://www.draeroheli.com
      Originally posted by draeroheli View Post
      Hi Align 3GX Manual does not mention about Flight Mode Settings. Is this an optional to enhance your flying or is this a must, part of the set up. I am new to this FBL and 3GX. Thanks. Htin
      Hey.
      The flight mode settings can be altered to suit your particular style of flying, from the bench they work ok but are not sparkling. If you download for example my custom settings file for the 3GX V2.1 and load them into the PC software, you will see what changes I have made to these parameters to alter flight performance.
      Ian Contessa
      Coolice Power Supplies
        Hi Ian, Thank you. Understood now. I went into Flight Mode Set up and Collective & Cyclic Dampening ( Green LED Status Light Flashes 4 times ) and tried to make my helicopter flies softer for beginner mode as I am new to this FBL and 3GX and the special servos arms I used were quiet beefy.
        As you know, it has been raining all day for several days and I can not wait of testing my new Trex 600EFL heli anymore and therefore I have to test hover the heli in my car port. The car port is quiet narrow on each side, the house wall and the car port wall are about 7 foot apart and there is only 2 foot clearance from the tip of the blade on each side. Happy Maiden hovering now.
        PS. 3GX Computer programme has a full instruction and there is a table as well as the key notes of the set up procedure. Well done Align.
          Thanks for the setup guide I was at my wits end last night trying to setup the tail on my t-rex 250 using the Align manual ( if you can call it that ) until I came across a pdf version of your post on google and now it is flying there is a video of the maiden flight on my thread here -> http://www.rcheliaddict.co.uk/t-rex-...-spinning.html
          So thank you
