Hi,
Just so I know if I've done this right. Set up the 3GX in DIR mode as per manual with 12 deg collective and 12 deg cyclic.
When I fly I don't want 12 degrees of cyclic. Say if I wanted 9 or 10 would I now just simply reduce my swash mix numbers down to get the required pitch?
Or do you set the pitch you require during DIR mode? Thanks.
