Can I change just one parameter in DIR?
  • Can I change just one parameter in DIR?
    Right, folks - thanks in no small part to reading all the threads on here, I have now finally got almost everything set up as it should be. Swash levelled, servos operating in right direction, pitch correct etc.
    However, before I got to grips with the DIR settings,I tried to adjust the rudder travel limit by lengthening the pushrod. I would like to shorten it again so that it will be mechanically correct i.e. with the slider in mid position when the servo horn is at right angles.
    My question is: Can I shorthen the pushrod, then enter DIR and simply cycle through to the rudder travel limit step - or do I have to go through all the other set up steps again?
    The tail is not set in dir. If you power on the heli and let it do its thing then hold the button for two seconds 3gx then goes to tail set up. Scroll through till younger your limits.
    It's exactly the same as setting the align Gyro's.
    If you have already tried adjusting through dir, I would go through it and reset the values again just in case.
    I always rebind after adjusting just in case it changes the failsafe.
    Sent from my Desire HD using Tapatalk
    Sponsored By
    Goblin 500-V bar T-rex700N with FLYBAR.
    http://www.lindensmfc.co.uk/
      Ignore younger bloody predictive text.
      Sponsored By
        On rudder set up you can go direct to the i.e rudder travel so long as you push button to save setting
        • Flickr Through My Pictures.
