slight wag, fast backward flight
  • slight wag, fast backward flight
    hi all
    finally maidened the 3gx 450v2 yesterday, i was quite impressed flew quite nice out the box, just a small turn on the ele pot, the only problem is a small tail wag in fast backwards flight. i am going to have a play with it first chance i get, just wondering if anybody might have any ideas as to cause or a fix
    adamf
    Sab Goblin, vbar 5.3 pro, 5025-440, Heli jive, bl 9180 & bl 9188
    Trex 700E, vbar 5.3 pro, PYRO 700-52, Power jazz 63v, bls256hv, and some swirling bright lights
    Trex 700E pro dfc HV, vbar 5.3 pro, 800mx, Heli jive, reactor hvx,
    Blade 130x
    The following might help:-
    Modifying 3G for better performance - HeliFreak
      HI,
      My V2 was exactly the same with wag but i had it on ff too... I started like on my other Align gyros at 35%. It was fine in a hover but in ff anf f/backwards it wagged like mad.
      I had to drop the gyro gain down to 26% and its fine now.. I do have some elevator nod when it gets some straight line speed but I suppose I just need to turn the ele gain down a touch..
      The HF thread is done on a nitro so an electric shouldnt have the vibes like that? Sod taking the 3GX apart tho
        Originally posted by johnsandywhite View Post
        Hey.
        This trick was for the 3G and not the 3GX Adamf has ;-)
        You could try lowering the rudder lock gain, it might be trying to hold onto the tail too tight which is giving the impression of too high a gain.
        I run a shorter arm on my 450's tail which allows a higher gain before wag sets in, might also be worth considering.
        Ian Contessa
        Coolice Power Supplies
          Thanks for the reply guys, I think I will have a play with the lock gain first and then play with the servo arm
          Cheers again everyone,
          adamf
          Blade 130x
            Hey.
            Oops. I meant to link this one:-
            3GX settings - HeliFreak
