3GX and retracts
  • 3GX and retracts
    I am in the process of converting my trex 450 to go into a scale model. It's stock setup 3GX with two sats running off a DX8. As I understand it gov is set to gear, and gyro gain to aux 2 at the moment.
    I clearly have two physical ports available at the back of the 3gx, in effect the s bus and bind ports. Is there any way I can use either of these to run the servo for the retracts, and in which case how do I set them in the dx8? Or do I either need to put in another fbl unit with 7 channels like the beastx, or run a separate receiver from the 3gx which will be a tight fit on a 450 to run the retracts?
    tx
    Blade 180cfx , 130x, nano cpx
    Trex 150 dfc
    Trex 450 dfc
    Trex 500 efl pro
    Trex 600e efl Pro
    DJI 450 Quad
    DX8 and DX9
    This rings a bell...! im sure i read someone else managed to do this so ill have a search & get back to you.
    • Flickr Through My Pictures.
      You'd need a separate receiver, but you could switch the 3GX to use that instead of the satellites if you needed to save space.
      It would switch gyro gain from channel 7 to channel 5, and would leave you free to use spare ports on the receiver for your governor or retracts.
      Electronics:
      Sims: Realflight / AccuRC
        Alternatively, if you're not using the 3GX governor, you could maybe use that channel.
        Electronics:
          Here ya go, read the 6th one down, Align 3gx /switchglo setup - Page 1
            Thanks all, I'll have a look at that tomorrow.
            Trex 150 dfc
            Trex 450 dfc
            Trex 500 efl pro
            Trex 600e efl Pro
            DJI 450 Quad
            DX8 and DX9
              Job done, thanks very much. Servo from the aux out port, in the dx8 switch for mix set to aux 3, then just a matter of getting the travel and linkage rods correct.
              thanks all again
              Trex 150 dfc
              Trex 450 dfc
              Trex 500 efl pro
              Trex 600e efl Pro
              DJI 450 Quad
              DX8 and DX9
                Hey All.
                Good to know, didn't know that about the AUXOUT.
                Ian Contessa
                Coolice Power Supplies
