3GX - do I have a problem
  • 3GX - do I have a problem
    Hi all.
    Helli is a T-Rex 550 pro DFC with a 3GX on V3.1.
    I had a very gentle blade strike on grass, main shaft, blades, and all servo gears were fine but I have noticed that just before the 3GX completes initialisation and bounces the swash plate 3 times the aileron servo goes to full deflection and jumps around a bit. Once initialised all is fine and it is fine in the air. Tried swopping the servo for a new Align 615 and that does exactly the same. I had not noticed this before and I'm sure it didn't used to do that.
    Any ideas would be appreciated.
    Martin
    After a crash its always best to redo the dir setup
    • Flickr Through My Pictures.
      Hello Martin
      My 3gx on my 600e started to do the same, so I just rebound and all was well. Has not done it since....
      Regards Adrian
      Regards Adrian
      I AM SPARTAN V4 + Spirit---TT--RAPTOR-E820 x 2-E755-E700--SYNERGY-E7SE--ALIGN-600PRO
      --... ...-- neXt
      A few bits and bobs & a few electric gizmos to stir the air.
        My 3gx has always done that once in a while. Never had an issue with it. Is the heli new? The blade strike might just have been a red herring.
        Synergy E7SE - Spektrum AR7200BX
        Align 600EFL DFC - Spektrum AR7200BX
        Align 450 Pro DFC - 3GX
          Thanks all. I'll try a rebind and DIR setup and see if it goes away. Heli is about 6 months old and it didn't used to do this.
