old 3G
  • old 3G
    Hi all im getting an old trex 250 with a 3g. Are they ok? is there anything I need to know or is it a case of chuck in bin and get a decent 1 cheers terry
    I had a 3g for a while and was great untill I got more confident with heli(250,450, n500 were all on 3g) n had a few problems with one unit (450) when throwing it about a little.
    Just make sure U hot glue gun the connectors on the unit as this helped on mine, but my 250 flew better with beast x, not tried any others
    BT/Openreach suck! 0.13kbps for months! Finally put on a temporary line 1.3mbps (unstable) since march 2013!
      try it as its fitted
      if you don't like it try something else
      Hirobo Turbulence D3
      1/4 scale Vario Bell 47 G3
      1/3 scale Vario R22
      2012 LHC Scale Cup Judge
        Hey.
        As Danep said, just check the connecting lead is fully inserted on the 3G. Otherwise it's a good FBL unit.
        Ian Contessa
        Coolice Power Supplies
          ok cool I give it ago im getting a vx1n at week end so il give it a try. if I like it I keep it and the 600 will get vtext. .... I will be abusing heli after a while
            I'm still fly my old M-Titan with the 3G & only sold the others to move onto the 3GX
            • Flickr Through My Pictures.
              I guess I better get an instruction manual and see if I can work it out
