Hi
I am going to check the pitch on my tail blades are correct by using rate mode on the 3gx,I know 0 to 50 is rate mode then 50 to 100 is heading hold and as you increase the % towards 100 you get more gain in heading hold,but which way increases the gain in rate mode?When I first maidened the heli I tryed to set tail up in rate mode with about 40 set in the transmitter and the tail just whiped round side to side which was unnerving.Heli is trex 550dfc and radio Futaba 14 sg.
Cheers Dave.
Cheers Dave.
