just noticed that one of my dsmx sats is not lighting up .Its on my 550e running the 3gx .can I use one of my dsm2 sats in its place .
dsmx/dsm2
dsmx/dsm2
Trex 550e dfc :-)
t-rex 450s x2 /Raptor 50
kyosho spree small plank
bogey combat plank x2 woop
http://www.cuffleymfc.co.uk
brian OB2proud owner of 3X E.G.S+ 1boggy special star
Tags: None
Not unless u reconfigure to use dsm2 overallGaui X4 II VBar - Trex 500 efl Pro VBar
Spektrum DX9
My Helifleet
I can put two dsm2 sats on but will the 3gx allow this.my tx is a dx8 if that makes any difference.just need to get it sorted before the weekend.i'll order one in the meantime.cheersTrex 550e dfc :-)
The sats have to be the same as the RX, either DSM2 or DSMXwww.heli-extreme.co.uk a good club in south Sheffield
The 3GX has only ever used DSM2 mode even with DSMX satellites so yes, it will be perfectly happy with two DSM2 satellites.
You will need to rebind of course.
Some hints that the new firmware may support DSMX but not confirmed yet.
Also, do check the wiring to the satellites, a faulty wire may be the cause of the current satellite not working so if you use the same wires for the new satellite you may still have problems.Last edited by Mark_T; 04-09-2013, 12:39 PM.
That is certainly true, when there is an RX in use, but in this case I think it is just the 3GX and the two satellites?Originally posted by moyesboy View PostThe sats have to be the same as the RX, either DSM2 or DSMX
If there is an RX on the heli as well then yes, that must match the satellites in use.
Thanks Mark.That is what I thought about the 3gx.good point about the wiring all I did was swap over the plugs to see if that worked but did not check the wiring connections.I have ordered a new one anyway but still need to check the wiring. cheers.Trex 550e dfc :-)
cheers Tye but should be ok as have ordered one and have a couple of dsm2's just incase.will see you there :-)Originally posted by WildWake View PostBrin if your going to the RCHA and need Sats for the weekend I have a couple you can borrow.Trex 550e dfc :-)
