hi,ive just built my new align 550 DFC with 3GX V3.1 and I don't seem to have found that locked in feeling I had with my 500 3GX!!?? it feels loose and a bit sloopy when I push it hard on tic toc's etc... anyone got any good 3GX settings I could test? also what gyro gain are you people using with futaba 8fg? im running 43% and think may be it should be lower to make it feel tighter?? many thanks jason
Any good 3GX V3.1 settings out there for the align 550?
try sending coolice a pm I bet he has some to help you out.Trex700E
sold
Dragons450 gy401 s9257
Mcpx
JRDSX9MK2
coolice Power Supply
Hi Jason.Originally posted by JAG1 View Posthi,ive just built my new align 550 DFC with 3GX V3.1 and I don't seem to have found that locked in feeling I had with my 500 3GX!!?? it feels loose and a bit sloopy when I push it hard on tic toc's etc... anyone got any good 3GX settings I could test? also what gyro gain are you people using with futaba 8fg? im running 43% and think may be it should be lower to make it feel tighter?? many thanks jason
What I have found is that the 3GX V2.1 settings I have posted a while back still work very well on V3.1, something I found surprising, but the combination of V3.1 and my settings makes for a nice feeling model.
I will attach the .txt file you can load up within the PC software before writing them to your 3GX to try.
You don't mention where you have your gain pots set to on the 3GX, I find the aileron is good set to about the 1 o'clock position and the elevator set to the 12 o'clock.
With the tail gain, like the cyclics, if the tail is feeling loose you will need to up the gain to get that tighter feel.
What servo arm length are you running? If stock it's a little too long and puts the control ball too far out. I mount my tail servo on the underside of the tail servo mount and then this allows me to mount the control ball on top of the servo arm/wheel to move it in closer to centre.
I usually use one of the small round disks with the ball set to one of it's holes, which is normally around the next hole in from what Align recommend.
.Attached FilesIan Contessa
Coolice Power Supplies
hi,thank you for that great info mate.i will test your settings on my 550dfc at the weekend and let you know.my gain pots are set at about 11 as I found over 12 gave a wobble! as for the tail,i am running stock as per the instructions. many thanks jasonAlign 700L TOP Spartan Vortex
Align 550DFC Spartan vortex
Blade 180CFX
Nano CPX
Futaba 8FG
That is great advice regarding the tail servo Ian, shall try that myself.
What gain are you guys reading on cyclics in the 3gx software. When I updated to 3.1 I had my pots at 12o'clock but they figures are not 100 (centre) as I expected?Trex 700e V1 3gx
Trex 550e dfc 3gx
Trex 450 Pro V2 3gx
