Problems with tail gyro on Align 3G
    Ds520 is fine at 6v
    Sab Goblin 570
    Sab Goblin 500
    500E Pro dfc
    450 Pro dfc
    Blade 300X
    DX9
      no dont need the step down on DS520 servo
      Santander Factory Team
      Proud wearer of 5 x EGS
        Originally posted by Made2Fade View Post
        The Gear channel
        That was the problem!! I was using an old set up for a Trex500 which I use with a 7ch receiver and this heli has a 6ch receiver so the gyro gain wasn´t set on "gear" on the radio... Now I´ve been able to set it up correctly, I´ll try it tomorrow.
        Thanks guys!
          Originally posted by 3dx View Post
          Ds520 is fine at 6v
          Would the servo last longer working at a lower voltage even though it can hold 6v?
            just leave @6v thats what it been tested at
              Hey.
              In order to meet the recommended speed and torque rating to compliemnt the FBL systems, the Aligh servos need to be run on 6 volts. The tail gyros benefit from a quick and powerful servo, so supplying the DS520 with 6 volts will allow it to work better for you.
              Ian Contessa
              Coolice Power Supplies
