I wonder if you could help I updated from 1.3.2 to v2.0 on my trex 700 nitro and in forward flight or coming out of a loop or a roll it pitches up about 10 deg
ive been on the spirit forum for advise but after trying all there suggestions ime back to square one
Might have to go back to version 1.3.2 because it was ok on that but I updated because of the gov
That's a strange one, the flight characteristics on mine were much the same after updating but i did go through the setup process again from scratch after updating.
The only thing i can think is that you might have the cyclic 6 degrees setting wrong, and/or you might have the cyclic ring setting too low.
Hi i flew on Saturday with the altered settings from the spirit forum and it was the same pitching after a roll
so I re set by wizard Sunday morning with the only differance Saturday cyclic ring set to 8 deg And Sunday set to 12deg
with the same result
also I've added 160 grams of lead to the nose to get c of g spot on and that's made no differance
