Originally posted by rapidgaz
View Post
Cheapo TGZ 380 FBL GYRO
I shall bewaiting for the flight report. Has it a flat bottom once out of the case daveOriginally posted by waveydavey View PostI'll test it Saturday, let you know how it goes
sent from me internetGaui x7 lush
Gobbalin 500
ALL ON SPEKKY GEAR
Blade 130x2
nano
Now I get it, the answer to that is no it hasn't as the edge connectors are 90 degrees to the main board. Just checked you can mount it upside down but you wouldn't be able to get to the set button or see the lights. It can mount on its side though or you could hang the edge connectors over a lip or something. If the whole box will fit I would leave it as it's no weight at all.Originally posted by rapidgaz View PostI shall bewaiting for the flight report. Has it a flat bottom once out of the case dave
Cheers dave, just waiting for it to turn up. Lol
Then I can get my esc and other bits I need. Going to be a fiddly job thou.
Gobbalin 500
ALL ON SPEKKY GEAR
Blade 130x2
nano
Hey dave, does it look easy to remove the board compleatly. And any chance you can measure it for me.Originally posted by waveydavey View PostNow I get it, the answer to that is no it hasn't as the edge connectors are 90 degrees to the main board. Just checked you can mount it upside down but you wouldn't be able to get to the set button or see the lights. It can mount on its side though or you could hang the edge connectors over a lip or something. If the whole box will fit I would leave it as it's no weight at all.
Gobbalin 500
ALL ON SPEKKY GEAR
Blade 130x2
nano
Yes will do mike, should be good fun. Or a teeth pulling excercise. LolOriginally posted by Mike Sanders View PostGood luck to you if you are going to squeeze that and an esc into a 130x. Please tell us how you get on an post some pics. Ta.
Gobbalin 500
ALL ON SPEKKY GEAR
Blade 130x2
nano
I've just mounted and set it up Gaz so don't really want to strip it all off again, it comes apart easy as per my photos above and the main board and edge connectors come with it, measurements are approx 33x23mm. The height is the same as a servo connector across it's widthOriginally posted by rapidgaz View PostHey dave, does it look easy to remove the board compleatly. And any chance you can measure it for me.
Ive got a wobbly 450 SE V2 that I gave away to my Niece's boyfriend a while back. I'm fixing it up now and wondering if this would be worth replacing the 3G.
Look forward to reports on this.
Shame I let him fly my 500 BeastX - he wants that now....
Taa
TrevTrev
