Sullvan Help please
  • Sullvan Help please
    I'm trying to remove the plank starter cup and fit my heli one way bearing drive to the Dynatron,
    However having undone the nut that secures the cup the cup still won't come off. Are they threaded on or just a very tight push fit? I've even tried heating the cup but it still wont budge
    Any help or advice welcome, I'm tearing my hair out at the moment.
    Sean,
    Logo 700 Xxtreme
    SAB Gobbler 700
    SAB Gobby 500
    T-Rex 700, Now FuBarred (Lol)
    T-Rex 700E, 12s Fun
    T-Rex 250 FBL, Less parts to break,
    DJi 450 FPV Flamewheel
    1 Very understanding Wife
    The stater cup is threaded on to the shaft!
      It is threaded but a mother of a job to undo I ended up cuttting the cup off with a grinding wheel lengthways just to split the thread.
      Good luck xxxxxxxxxxx Rachel
        Tight, thats an understatement.
        I must admit I did consider grinding it off but was a little concerned about damaging the shaft with the grinder but I'm thinking now you've suggested it, it may be the way to go.
        Thank's Rach, if it goes pear shaped I'll blame you
        Sean,
        Logo 700 Xxtreme
        SAB Gobbler 700
        SAB Gobby 500
        T-Rex 700E, 12s Fun
          don't cut all the way through it score it deeply on one side cut as deep as you dare on the other insert a chissel and wack it !!!! It will split leaving the shaft undamaged but wait a while and see if anyone has any better ideas .
          sorry but Its the best I can do ;-)
            Heat up the cup, think it's made of alloy so just use a small gas torch
            Sent from me
            Gaui x7 lush
            Gobbalin 500
            ALL ON SPEKKY GEAR
            Blade 130x2
            nano
              Wrap the shaft with coarse emery then grip it with narrow nosed mole pliars. Heat the cup with a gas torch and then give the cup a tap to undo. Guarantee i'll work!
                You TART.
                Infact I'd put on it and I'm not a betting man. Thanks for your help this evening mate, It did take some serious OOOmph to get it off though hey.
                Sean,
                Logo 700 Xxtreme
                SAB Gobbler 700
                SAB Gobby 500
                T-Rex 700E, 12s Fun
