Mixture on os55
  • Mixture on os55
    I am hoping to run in my new os 55 this week. And as I have two mix screws to work with now. Could any one tell me what the best starting Point is? And after I have run in should I adjust both or will it only be the one.
    Matt
    Starting point to run in is 2 turns out on both needles... after its run in and you have leaned it off it should be somewhere in the region of one and half on both needle .. this is with 55 pipe and 30% fuel ... TBH this is only a rough guide for finished settings as it depends on too much
    Knight 3D
      That's great thank you.
      Matt
        I struggled to get an 1850ish headspeed with these settings Mike, I had to come in a couple of clicks just to get it off the floor.
        Had a gallon through and sitting a couple of clicks over 1.5 turns out. Using the highflow tt pipe.
        Your really going to like it Matt, I've never seen my 600 climb like it does now, the biggest loops you can imagine, only ever seen them with a 90.
        Mike, do you struggle to get through idle to mid with the above mid needle setting.
          Dave ... when I had the 55 I was on 20% fuel with an outrage 55 pipe and ended up on turn and quarter on main needle and about the same on the mid ... with the bottom end just a little turn lean from centre ...
          Knight 3D
            Your really going to like it Matt, I've never seen my 600 climb like it does now, the biggest loops you can imagine, only ever seen them with a 90..
            Yes I'm looking forward to it, it was only a few months ago that i was backing of the power with my os 50.
            Matt
              I started on 2 turns out as per the manual.. idled through 3 tanks first before getting it off the ground.. but at 2 turns out (1882), it was stupidly rich that you can see a river off fuel come out of the exhaust!
              I'm still running rich at 1/3 and 1/5 but happy to leave it there to save some bearing.. but previously I was just under 1/4 on both which was really sweet!
              Eddie
              Velocity 90 FBL BeastX V3
              Trex 600 LE FBL BeastX V3
              Trex 500 EFL Pro BeastX V3
              Fusion 50 FBL
              VBar
              All powered by a DX8
                really want to try this high flow pipe
                Sponsored By
                Goblin 500-V bar T-rex700N with FLYBAR.
                http://www.lindensmfc.co.uk/
                  I think you'd like it Ian. I could easily add more pitch to my setup but I don't think I'd be able to handle it to be honest. Theres a point in the video of Matt Botos flying the N5 where he takes off into sky at a rate I've never seen at about 4 mins, my 600 is just the same. I can't believe how smooth the power is.
                  [ame]http://www.youtube.com/watch?v=yGc6-JzyqPY[/ame]
