Hi Everyone,
Was happily flying my OS91HZ-PS equipped Srimok when the revs rose rapidly and the engine quit. Autoed in safely and upon checking the regulator was on the floor (retained by the fuel tubing). The main needle was completely missing!!
Not sure if the engine vibration cause the needle to loosen but I must confess to never having checked the tightness of the needle in the engine casing - lesson learnt!.
Does anyone know the best place to get a replacment Main needle valve assy (Pt No OS 29181900) as its for the PS it seems to be a difficult one to locate. (are any of the other OS main needles compatible?)
Also in the exploded view the regulator is held onto the casing with washers either side of the reg. The washers are not listed as seperate parts, do you think that these would be supplied with the needle assembly?
Gav
Gav
