I changed the engine bearings for the first time last night on my OS55.
It is the first time I have changed the bearings in any engine, not just this one.
Looking at the old bearings, it was clear that the larger one (rear?) was in a poor state, quite rusty and it felt notchy when turning it. However the smaller bearing still looked perfectly fine (although I damaged it slightly when pusing it out).
Is it normal practice to change both bearings at the same time? Or does anybody just change the bearing that needs changing?
I did change both. I ordered ceramic bearings shortly after buying the engine because I was advised that the original bearings supplied with OS's fail pretty quickly. As it happens, this engine has had about 5 gallons through it.
Andrew
Andrew
