And if the bearing has had metal bits hit it, that is probably knackered also, so check it
os 50 went bang!!
cool yeah how much you want for itOriginally posted by savinay3 View Posti have piston ring and liner if you want them or an entire engine minus the crank, they came of a engine which had done 4 gallons, i was changing the back bearing on it when i got the crank out the bearing was stuck to the conrod so i tried to get it out but bent the crank shaft so have the whole engine as spare.
Cheers Paul
Avant Aurora fbl
Synergy N9 ys91srs
Sounds like a good description of a traditional Japanese bath house ...Originally posted by waveydavey View PostSoapy water, soak it in a dish letting all the bubbles go giving it a good sake in between. Repeat a number of times and then set it on a rad to get rid of the water left. Give it a polish and off you go.
Normally need to pay extra for the 'polish' though
This is why i put the post up last weeklOriginally posted by Geek View PostBecause there is more oxegen in the cold air you need more fuel to run it at the correct ratio.
Not sure how old you are and if you drive a car.
but if you drove a car with a choke you need it more in cold weather
http://www.rcheliaddict.co.uk/engine...er-leaner.htmlVelocity 90 FBL Beast x
Outrage velocity 50 nitro,
Beam E4
Futaba 10 CG
Cold Weather fuel
2 clicks rich in cold weather, been out this afternoon with my YS91ST in TREX700 doing cold weather tests on OH2020SLV -3 degrees here, never missed a beat, supurb even if a say so my self!
Oil gets very viscous in the cold another good reason to use SLV fuel much better and idles really well in cold.
How do you know Mark?Originally posted by Mark_T View PostSounds like a good description of a traditional Japanese bath house ...
