OS50 SX bearings
  • OS50 SX bearings
    i know it has been covered before, i need to get some new bearings , skyline list spare parts for the os engine but no pics so im not sure what the part numbers are for the bearings, does anyone know or know where i can get some.
    thanks
    T-Rex 600LE - canomod - OS 50 - Spartan DS760 - 610's, 650 tail, NHP's-Spektrum Telemetery-Rapicon20%
    Raptor 60 - Hatori - 401 - BBT 710's NHP 105's MD500 scale fuselage
    Align 450pro stock
    Trex 700LE - FBL- RJX Head - OS91sz - 610s, BEASTX V3 - 650 tail - 30% Optifuel
    Trex 250 new edition to the family
    Pheonix 3.0s
    Spektrum Dx8 v2.0 DSMX
    Do a search for 6902 bearings without any seals or shields they are 15 x 28 x 7mm. You should be able to find them around £3 or £4. Consider them as consumables and don't pay the OS prices. If you can't discern when bearings are going bad look for bearings with the platic retainer.
    The front bearing doesn't go in a hurry and probably won't need changing. Its part number is R6ZZ.
    Member of Mk Heli Club
      thanks, you sure about that size for the os50? mine looks 22mm ish
      Align 450pro stock
      Pheonix 3.0s
        If I was not sure I wouldn't of posted. Anyway if you look for 6902 then the size won't matter because that is the correct part number.
          Trust me Andy will not be wrong. If you are referring to the outer diameter are you not mistaking the front one which is indeed 22mm x 9.5 x 7.
          Edit : I was a bit late, told you though!!
            thanks chaps my mistake, i did look at the size for the front one!
            Align 450pro stock
            Pheonix 3.0s
              rear bearing Fast Lad Performance
              Front bearing Fast Lad Performance
              I'm just looking now for the same bearings!!
              Synergy N5 -BeastX
              450 Pro -BeastX
              Black Horse Sukhoi 31
              DSX9
              Eagle RC Heli Club
                OS Bearing Sizes
                Very Proud Owner of 1 EGS!!!!
                _____________________
                  looked at those! well overpriced, im going into Berkshire bearings tomorrow, going to get a handfull
                  Align 450pro stock
                  Pheonix 3.0s
                    just ordered a front and rear from here RCbearings.co.uk, For a friction free RC!
                    £5
                    Synergy N5 -BeastX
                    450 Pro -BeastX
                    DSX9
                    Eagle RC Heli Club
                      ive just done the same! thanks for helping heliaddicts
                      Align 450pro stock
                      Pheonix 3.0s
                        Gosh, I had them over-priced then didn't I? £2.00 each what a bargain. Buy a dozen and treat them as consumables.
                        And there was Spanner off to FL to pay top whack. Well done chap for searching these out.
                          model fixings is another great site for os bearings
                          adieuk
                          x7 eddie gold stars!
                          www.eaglerc.co.uk
                          dx7, phoenix sim
                            Hey spanner, not sure about those they seem too cheap, have you used them before?
                            Just been pointed towards simply bearings on the A580 (South Man) but they are £20 each.
                            Having said that, the one my tutor has in has been doing 30-40 flights plus a week and is still good after 6 months (Seems worth it) - I'll research exactly what's special and post back with details.
                            Raptor 30V1 Maverick Head
                            OctoCopter
                            Futaba 14SG
                              Try
                              Which one should you buy ??????
                              Simply Bearings Ltd ~ Oil Seals SKF FAG TIMKEN KOYO NTN NKE TRULOC Needle Rollers Taper Rollers Rod Ends Oilite Bushes Loose Balls O Rings Grease Plain Thrust
                              OctoCopter
                              Futaba 14SG
