Os power boost pipe???
  • Os power boost pipe???
    Any one running one with an OS55HZ?
    What are they like?????
    noisey or quiet?????
    Wont be getting another Outrage 55 pipe after the manifold snapped on me today
    I use a hatori, as was advised that the power boost pipe doesnt perform as well as the hatoris do.
    Troll buster
      Hi I ran one on a vibe 50 which has a slightly odd gear ratio 8.7 to 1 which may not have bought out the best in the os pipe but I found it slighty peaky and a little noisey but I swapped to the Curtis MP5 and loved it
      remember this is just one girls thoughts
      's x rachel
        I like it just the money puts me off.
        think Hatrori is better but not tried on a 55.
        Have one on a 50.
        Cheers Paul
        Citizen #42
          Not even with the 50% replacement Nick?
          Eddie
          Velocity 90 FBL BeastX V3
          Trex 600 LE FBL BeastX V3
          Trex 500 EFL Pro BeastX V3
          Fusion 50 FBL
          VBar
          All powered by a DX8
            I had a GP 57 which I switched out for the OS powerboost pipe.
            Powerwise I felt it was very similar but it sounded better than the GP 57.
            More smooth sounding and a little less raspy if that makes sense.
              Not thought about that,but it will probably happen again.I remember seeing alot of reports of the same thing happening with the outrage after i bought it
              Dont know what to do,must say i like the quietness of the hatori's but may take a punt on the power boost as i can get it local with discount.I also need a gov sensor which they also have in stock
              Wish id never swapped it for the align 50 pipe TBH
              But my local hasnt got any in stock....which makes me want to try the PB
              Bloody heli parts breaking in flight WTF
                I didnt come across any posts about the 55HR breaking.. just the pressure nipple problem
                If your after a Align 50.. I have one thats had just two gallons goe through it.. and not a mark on it, if your interested... but then again.. after this post.. i might keep it as a spare, lol!
                Eddie
                Fusion 50 FBL
                VBar
                  Thanks for the offer Ed but if i were you,id keep it
                  Didnt find much more power with the outrage over the align 50.
                  There was one or two who said they had the manifold break,i remember seeing a pic of the same breakage i had today
                    TBH, I thought the same... also I didnt find it that quiet either!
                    Eddie
                    Fusion 50 FBL
                    VBar
                      Ditto,about the same
                        Are your bearings holding up ok Nick?
                        Only ever time I had a manifold go was due to the death rattle of old os bearings.
                        Martin
                        Aka RCSlopesurfer
                          Yes Martin,been much better since blowing all excess gas out othe engine.
                          Every time i have heard the death rattle i acted straight away
                            i have the zimmerman for my 55, was told it provides the best power and is unbelievably quiet!
                            It's all about the size of your chopper...
                              Well,i have put the OS power boost on,looks nice and good qaulity....just hope it isnt a crazy frog zorst....a rin tin tin
                              Will try it this afternoon
