Hello,
the particular engine I've got is probably quite rare, but it shouldn't be too different from a YS 91 SR.
Where I am now:
* Hatori SB 19 FH-2 muffler
* Optifuel 30 %
* OS #8
* an OS bubbleless clunk, a headertank and a fuel magnet. Total overkill, at least temporarily.
* at sea level
I had to shim the engine- After putting in a second head gasket, it now purrs like a kitten and the needle settings in the manual make sense. Without the second gasket, it runs unevenly and too hot.
Right now, it gives pretty good power. It's probably the best-performing nitro engine I've ever flown. It does F3C-size loops and barely bogs. Not too bad.
But still, it's no good for tictocs. In the "hard ones" (tail rotor facing up), it bogs miserably.
I set the hover needle first, the engine remains cool as long as I only hover. Then the full needle to keep it cool at continuous full power. In hovering, it runs relatively lean.
But now I'm wondering: Would it be better to set the hover needle as rich as possible? So that the engine gets maximum cooling when it doesn't have to deliver full power?
BTW, I noticed that the governor (Aerospire multigov) seems to perform better in tictocs when I disable feedforward entirely, i.e. a flat 100 throttle curve.
Or, asking more generally, how would I tune this engine to get crazy superhero powers, so that I can start practising wheels of fortune?
Where I am now:
* Optifuel 30 %
* OS #8
* at sea level
