Couple days back I had a piston failure on one of my 57,s I'm a bit gutted as it seems I can't get the piston separately making for a prohibitively expensive repair.
The failed motor is my much lower airtime one and was my 'good un'
I could have accepted it happening to my other NR which I accidentally cooked at 3DS. Ive since stripped that motor and replaced the ring/brg and is now performing superbly again which is a testament to it's build quality as it was damned hot as I was forced to fly out my 'Sets' ( the oil in the exhaust was crackling from the heat)
The offending engine has never been lean and run mostly around 1975 and a little at 2100 on 8:5 ratio meaning it's not working very hard at all and a piston or ring failure was completely out of the blue which surprised me.
Even stupider is NR supply a liner separately but not a piston!
I'm in two minds about this as the NR knocks spots of other big block motors in the power stakes but piston unavailability is not acceptable unless you buy a liner and ring with it
I ain't springing for a new motor for sure at the mo. Mmmmm
... The NR does look a nice engine and some people have said it pulls like a 60 year old hooker ...
mines had 13/4 gallons through it and i've still got its original bearing in it
