Novarossi Rear Bearing for R57HR3D
  • Novarossi Rear Bearing for R57HR3D
    I'm looking for a rear bearing for my 57. Does anybody know a dealer in the UK who has stock at the moment? Any info welcome.
    Justin
    Synergy N9 FBH FBL | Synergy N9 SE | T-Rex 600 | Synergy N5
    Originally posted by serpent887
    I think the Rossi 57 uses the same 15x28x7mm bearing as used in the 50 OS, the TT Redline and the YS.
    Don't think it is. My mate's changed the rear bearing on his 57 and says it's a demountable tapered type, unlike the standard ones used in the other engines.
    JR Vibe Fifty fb (YS56)
      Bump
      Is the only solution a £25 bearing?!
      x 3
        Bit of an old thread Paul?. The bearing is patented and made by Nova Rossi.
        The difference is the track the balls run in is offset.
        Brian
        Fast Lad Performance
        SPARTANRC Team pilot
          Was searching for the info after contemplating buying one.
          Cheers for the info, cant see me shelling out £25 a bearing though
          x 3
            i have just purchased one paul and i had done some research first and bearing changes are far and few between compaired to the os55 and you have more power than a 55 its a no brainer
