Engine eating glow plugs
  • Engine eating glow plugs
    So I seem to be using about a glowplug a gallon for the last 3 gallons. The engine is running cool and rich, and has no rattles from cold. I have read that this could be a sign of the rear main bearing failing as the particles of metal damage the glowplug. Is it time to pull the engine and change the main bearings ? Its an Align 91 H (OS 91 Hz) with 15 gallons use (with a Rob GT set headspeed - its set somewhere between screaming and wailing)
    If so where is a good place to source replacement (non OS price) bearings? somewhere online and in the UK would be ideal.
    Oliver Crawford - Align 12S T-rex 600e, Align 610 x3, Spartan 760, tail Align 620, Scorpion 4025-630 KV, Bec pro, Castle Creations HV 80A ice.
    Align T-rex 700e, Align 610 x3, 3g, Spartan 760,Align 650, Bec pro, Castle Creations HV 110A.
    Could try Here for bearings mate.
    Del
    Climb-Out
    3D Scotland
    Proud owner of 2 EGS
      Before reading the content of this thread (just the subject line) my first thought was the back bearing!
      Last time we flew it Oli, it was tuned nicely , so I doubt it's lean runs killing them?
      | 3D Championship
        Do they usually only last 15 gallons or so rob? (I do have an issue with fine sand where I fly near home). Where do you source your bearings from? Ever had a problem with metal caged ones?
          I've bought aftermarket bearings from Modelbearings previously - as linked above.
          How long they last will vary depending on lots of things.
          The sand issue you have won't help matters I'm sure.
          To be honest, 15 gallons isn't great, but it's not terrible either...
          | 3D Championship
            my 50 hyper is eating them at an alarming rate, as in one every other flight. ive replaced the rear bearing and the ring to no avail. im a bit stuck on this one, its tuned fine, not running lean at all
              If that's in your Knight 3D, have a chat with Richie as he went through the same problem, but I think got it resolved?
              | 3D Championship
                ill pester him on msn sometime soon, cheers
                  I also heard using a silicone sealant to seal the exhaust to the engine can cause premature plug failure (alothough I find it hard to believe). Might be worth considering though Jamie.
                    Yes, it can - if any excess makes its way back into the engine it will kill a plug.
                    | 3D Championship
                      Apart from the obvious running lean..does it hve the Death rattle at idle? (bearing)
                      Assuming not I would reckon something is out of balance/alignment like the clutch in the motor stack.
                      A partly split clunk line may cause it to run lean part way through the tank but OK on full. So it's a good idea to check temps throughout the tank..e.g. 1/2 1/3rd.
                      cheers Brian
                      SPARTANRC Team pilot
