Early this year I bought a 105HZR, what appears to be a curse more than an engine. When I got it had loads of regulator issue, always cutting out mid-flight costing me a nice set of edge blades and a lot of tinkering, a 100ish pound service later on my regulator. The next two flight went ok, then cut out mid-flight with almost bogging itself to death on a rainbow reversal. What appeared to be a dead glow plug, did exactly the same thing on the second flight this time with a bang clonk, clonk, and nasty auto to safety, having killed an OS50 during my initial nitro days I knew pretty much what that was about. guess the first glow plug burn out was the clue to start with as it was coverd in gray matter what was basically fine pieces of ally being thrown at the plug from the piston. So now I have burnt out piston with a big hole in it and scored liner. Looking at the cost of a new linear, piston, bearing and ring etc…I am going back to my spare 91HZ for now.
Now what is suspiciously wrong is;
My needles are 2 1/4th on the main and 1 ¾ on the high so I am running super rich. This is with a Hatori muffler it came at about 2ish turn I have tuned it to the richer side as it was running way too hot for my liking and flew fine for the few flight I have had with it (count that to be about 5), It made good power so I hadn’t got to tuning it lean yet or not that it gave me a chance. So how can it run lean, it must be super rich unless the regulator had something to do with it again. Having tried all know tricks on the net to check regulators, it appears to be working correctly.
Next up I bought some stainless steel bearings from RCbearings which appear to be completely rusted, so much for stainless steel, they will be hearing from me shortly. I doubt that this would be the cause I have seen worse rusted bearing in nitro cause very little issue.
So I am baffled as to what’s has gone wrong? any ideas would be much appreciated.
When I first started in this hobby one of my club mate use to say nitro’s either work for ever or they are your worst nightmare, comes back to mind. Had a few nitros now running for ages without touching the needle once and some that won’t let me sleep at night
