Fuel Tube T Piece
  • Fuel Tube T Piece
    Hi all,
    Has anyone got a link to the T piece I need? I want a quick, easy way to relieve the backplate pressure from the tank after each flight and I know many use a T piece and removable bung.
    Thanks!
    Harry
    Powered by Futaba 18SZ
    I use the dubro ally t's but take a look at aquarium T's for air pumps, I use them too.
    Here you go
    Nylon Fuel Fittings SUL486
    Or, the Align fuel filter and remove the filter, can't find the Dubro ones
      halfords
      washer jet t piece
      or use an align fuel filter/filler
      Hirobo Turbulence D3
      1/4 scale Vario Bell 47 G3
      1/3 scale Vario R22
      2012 LHC Scale Cup Judge
        Thanks! Would they grip strong enough? Are they ridged like the header tank connectors etc?
        I have a spare align filter. Could I just take the filter out and use that?
        Harry
          More than strong enough mate, the other little tip is to cut 1-2mm of fuel tube from the end, force some pointed pliers into them and open out. Pass the fuel tube through and you've got a securing ring of tube. They're not normally ridged although you can get them like that, I keep fish too. Yes, just take the filter out and you're sorted
            so is the fish supper at mk
            home grown ?
            1/3 scale Vario R22
              Yeah that's what I do - use needle nose pliers to stretch about 6mm of tubing over the end of other bit. No way that sucker is coming loose!
              Harry
                Is this what you are after Harry? : 29084610 OS T Nipple
                Thanks!
                Rossco
                Equipment for Sale:
                  Thanks that's perfect but I don't want to pay £7 ha. I'll try the align filter option first. I'm just next to a halfords top so I'll pick up a t piece from there also.
                  Harry
                    Typical, Halfords didn't have the 3mm piece in stock. But I found an old filter. Here it is fitted. Any recommendations for a better bung than a m3x8 bolt with a washer (for grip)?
                    Harry
                      One of these will do the job (not the perfect T piece, but as said earlier, if you take out the filter it will act as such, and also give you the retainer part! Or, a couple of these will keep you in clean filters for a while, give you a perfect filtered refuelling connection if put between the carb and fuel tank and also the spare retainer for easy pressure release with no risk of losing the piece when refuelling!
                      3-Way Fuel Filter HN6022 Model Helicopters
                      (sorry for sketchy quality of photo but you get the idea!)
                      Raptor G4 - Radix 690s, OS 91HZ, Spartan Vortex v3, MKS HV servos, OptiFuel 20%
                      Logo 600sx - Edge 603s, Turnigy 120HV - Scorpion 4035-500 - Mini Vbar - Savox servos
                      Logo 550sx - Edge 553s, Turnigy 100LV - Scorpion 4025-1100 - Mini Vbar - Futaba 451/251s
                      Blade 130X moneypit shelved
                        Cheers dude! I should have one of those plastic bung things kicking about somwhere, I'll see if I can find it. Failing that, an old plastic ball link might suffice aswell...
                        Harry
                          I use these festo fittings harry, from nexus model supplies, used in jets for airline and fuel so good for glowfuel. 4mm Festo Barbed MS T Air Line Connector MS-T-4mm FE4TB - Nexus Modelling Supplies
                          Happy Flying! Thanks - Dave
                          Sponsored by my own hard work and my good friend's Visa & Mastercard.
                          GAUI NX7 / OS105HZ-R / Powerboost Pipe/ Spartan Vortex VX1N
                          GOBLIN 770 / Scorpion 5025-440 / YGE160 / Spartan Vortex VX1N / GensAce 14S Baby!!
                          Curtis Stingray500 - FPV Pylon racing
