Nitro RPM sensors?
  • Nitro RPM sensors?
    Can i use this for a Vbar governor?
    Spektrum Aircraft Telemetry RPM Sensor and Bracket SPMA9569 - Nitro Hobbies Inc.
    If not, any suggestions? its for a Synergy N7.
    Ta!
    TT Raptor G4 + Vbar
    Hi Delarado,
    That particular sensor is for RPM Telemetry i believe, this is the backplate sensor for governor use:Spektrum RPM Sensor & Bracket With Standard Servo Lead SPM9560
    I think people have used the telemetry sensor in the past when the SPM9560 backplate RPM/Gov sensor has been out of stock, but it has required that the plug be changed to a standard servo type connector.
    You can also make your own sensor up to use magnets in the clutch bell using the following:
    Magnets for clutch bell: Spartan Governor Sensor Magnets SRC-MAG
    Sensor:Aerospire MultiGov Sensor AOR020
    Bracket:CSM Synergy/ T Rex 600N Govenor bracket CSMRL19
    Hope this helps, any questions give us a shout.
    Ross
    Thanks!
    Rossco
    Equipment for Sale:
      Thanks mate, absoloute legend!
      TT Raptor G4 + Vbar
        you can use this i have it set up on my 700 its great
        its full of meaty goodness
        GAUI NX 7 V Bar silver line
        Align T Rex 700 F3C Flybarred
        Align T rex 600 le DFC Vbar blue line
        SAB Goblin 570 Kontronik jive + pyro
        450 pro DFC
