Hi all - I started my OS 50H with TT redline 3D Hi-flow after fitting new bearings but she sounds bit rough to my untrained ear. I cleaned it out at the same time, the piston and ring has been cleaned up and lubed so the ring can move freely.
As you can see, even after it is warmed up it will only restart if I give a little move throttle stick than normal.
I was wondering if you guys could have a look at the videos and see what you think. The first video shows what it sounds like from low to med range revs and back down and the second video shows how the revs pick up after the fuel line has been shut off.
Video 1
Video 2
Thanks Guys
Video 1
Video 2
Thanks Guys
