cylinder liner and head becoming one
  • cylinder liner and head becoming one
    hi all
    took my os 50 hyper apart yesterday to have a look to see why it had a poor top end power....
    as i took the head off, the cylinder liner came with it!
    i know these 2 bits are meant to be separete so i am now trying to get them apart
    i have tried:
    freezing it all in a freezer, then putting the head into boiling water
    and
    putting it in a vice and hitting it with a hammer....
    i am now completly stuck on firstly why it would have been stuck in there (got it secound hand from an experianced pilot and he dosnt know why)
    and secoundly why i carnt get it out! lol
    hope u can help
    I think you know the answer now Tom..
    Not an expert but if the liner came with the head as you say then its not good chum.
      Try warming it up....gas powered soldering iron/blow torch will do.
      www.lincsheli.com
        warming the whole thing up?
        i have tried that with a flame, a toaster and a cup of boiling water
          gloves and a hat???
            not sure there gunna produce much heat boggy
              stick it in the oven for a bit. same as you would for changine rear bearings.
                jeffing genius!
                i just ruled that out because i thought it would just be the same as toasting and flameing for example....
                but 15 mins at 200c and it simply broke apart...
                soo happy now
                thanks for all your helpss
                  If you pop it back together but leave all the head bolts evenly undone by about 2 turns.
                  Then attach the fan or a propeller and turn it over by hand, the compression should break the seal.
                  Whoops you already did it, too much alcohol, me eyes have gone fuzzy
                    I take it this is out the 3D Tom???
                    Lee
                    Lee
                    www.raptoruas.co.uk
                    www.lee.rcha-uk.com
                    www.gensace.de
                      yes lee
