Scorpion Sky Strider 280 Racer
    Lemon RX is the best option lots on ebay
    Have a look at http://youtu.be/S86HiiawwUA
    It's for Vortex but similar
      Will you need a PPM RX for the control board? If so like already stated the lemon is the best bet.
      Goblin 380 - Vbar Control and Neo
      Goblin 570 - Spirit
      T-rex 700E DFC Pro - Spirit
        [QUOTE=Scotvar;1194254]Will you need a PPM RX for the control board? If so like already stated the lemon is the best bet.
        PPM RX ??????
        Ive brought a distributer board so everything can run from that power wise . so why cant I use a Ar6100e RX ?
          Hi
          The AR6100e RX does not output a PPM signal. The PPM signal is a all in one wire similar to X-Bus/SBus, I'm not sure if the Naze 32 full can take individual channels... I have always used PPM. Spectrum do have a PPM Rx now though if you wanted to keep it all the same or the Lemon stuff is very good. Just stay away from the Orange stuff
          EDIT- The NAZE32 can take up to 8 channels
          Rich
          SAB Goblin 700C - Black Nitro
          Flight Log
          THE MEDWAY MASSIVE
          WEBSITE FACEBOOK
            this one ????
            Spektrum AR7700 Serial Receiver w/ PPM/SRXL/Remote Receiver Output # SPMAR7700 | eBay
              Ar6100 is dsm2, and new spektrum transmitters don't support that due to the latest eu regs.
              I'd also go for an orange or lemon rx with ppm or sbus.
              Spektrum finally released a suitable receiver, but it's horrendously expensive.
                Yes i know as ive just ordered one lol ! Spektrum are expensive but after all the money Ive spent I might aswell have one .
                  Nice one, please let us know what you think of it. I've been using the lemon and rate it highly. No latency at all. Be good to compare them.
                  Goblin 570 - Spirit
                    Will do as soon as it arrives, I should have it all finished for next weekend fingers crossed .
                    • #25
                      Hi ive got the Sky Ryder with the scorpion 2205x2350 kv motors using a vector controller,all I can say is you wont be disappointed with the flying of it,I do have FPV on it but mainly fly LOS,Marty
                      Chase 360 and JR Ninja all controlled by JR XG8
                      proud owner of 2 EGS's
                      • #26
                        Thank you ! Im really looking forward to getting it finished , juts waiting for parts that didn't arrive in the post today grrrrr ! So I went to the Droneshow at the NEC and basically nobody selling parts would you believe it lol !
                        • #27
                          So now I have all my parts , Ive got a distributer board that has a 12v output and variable 5-20v output , which do i use for what ?
                          Do i also mount the Naze32 on pegs provided or sticky pads like my other giros etc ??????
                          Learning curve i know and thank you for all your help .
                          • #28
                            5-20v is usually to power your naze board, set to 5v. Putting much more than 5v through it will toast it.
                            The 12v is usually to power your camera if you are running 4s. In reality, it will depend what voltage your camera can take. Most CMOS cameras are 5v, which are usually powered from the 5v out on the vtx if it has one. CCD cameras tend to be 12v, though there are exceptions.
                            Naze is usually mounted on pegs, though you can double sticky it down as long as you get it square to the frame.
                            • #29
                              So ovr the weekend I have now got my Camera working and my googles too , the pictures ok . The camera and TX is running on 12v and I have taken a 5v lead which will power into the Spektrum RX and Naze32.
                              Just looking at the Naze and Spektrum connection there are three holes that need to have the wires soldered into and them it just plugs into he RX ???
                              • #30
                                Or this way using yellow to connector 4
