on the screen when looking at the throttle curves there is a bold verticle line that moves left to right when the throttle stick is moved, should the line settle on zero when the stick is at its lowest position.. mine moves a little to the right with no input on the stick and im beginning to think this is the reason my trex spools up with no input on the throttle... my throttle hold is set to - 0.05
DX6i and throttle curve
Is your stick tension too high this can cause them to rest slightly off the stop.? Maybe set your hold at 0.1 to compensate.
Oh and yes the line should show zero
as you've probably guessed it shows you the stick position relative to your throttle curve.
Back to Horizon hobbies at harlow.
Address;
Horizon Hobby UK Ltd
Units 1 to 4 Ployters Rd
Staple Tye,
Southern Way,
Harlow,
ESSEX CM18 7NSTelephone;
44 (0) 1279 641097
Fax;
44 (0) 1279 428863
