DX6i - changing batteries
  • DX6i - changing batteries
    Can't find the answer, unless I'm looking in the wrong place!
    The question: I'm new to rc helis, recently upgraded to a Blade 450 and DX6i (together as a RFT bundle); I'm still on the first set of alkaline batteries for the DX6i, which now has the 450 and my Blade mCX2 on it. When I have to change the batteries, will I lose the settings and bindings? In which case I presume I'll have to spend time hand-copying them and re-entering them manually. Or are the settings proof against removing batteries - the DX6i came with the 450 ready-set, so I guess the settings are safe?
    Side point: when I change the model, the DX6i says DOWNLOAD... What is it downloading, and from where??!
    Owen
    Blade mCX2 - indoor use, slightly chipped
    Blade 450 3D - outdoor use, slightly grass-stained
    Blade Nano CPX - indoor use, slightly lively
    Blade mSR X - indoor use, slightly less lively than Nano
    Spektrum DX6i, Phoenix 4
    plus some spares and a lot of optimism
    Just take out batts and replace with another ser
    If you change to another model memory will display downloading
    Santander Factory Team
    Proud wearer of 5 x EGS
      You wont loose the models and settings stored when changing batteries!
      I presume the downloading is from the built in memory that holds all your settings and models. It will then in the download go through initialisation for that model I would presume.
      http://www.rc-hero.co.uk
        Owen
        Owen - no, you don't lose anything. I use rechargable nimh batteries and take them out regularly to charge them.
        The downloading is when it downloads the model settings from non-volatile memory (hence why you don't lose the settings), into the working memory for controlling the heli.
        HTH Tom.
          Ah, thanks all, that confirms what I'd thought about the batteries - irritating that the DX6i manual doesn't say that, though.
          And thanks for clarifying the download thing too!
          Owen
