Version 2.06
24 September 2012
Software Features
• Automatically corrects sub-trim and travel for models created in version 2.04 and
earlier after prompting the user. This is functional both for models already in
your radio, and for any you import from an SD card. You should always verify
operation of a model when making any updates prior to flying it.
Software Corrections
• P-Link Master Trainer mode was using trainer data for channels GEAR and
higher.
• When a channel is reversed the endpoint adjustment worked on the opposite
side from what was expected.
• Improved French translations.
• Added SD logfile indicator to main screens.
NOTE: This change affects sub-trim and travel of existing models and ones you will
import. You should double-check sub-trims and travel on any reversed control surfaces
in both airplanes and helicopters when using models created in version 2.04 and earlier.
MY NOTE: on german forums users are reporting that the issue introduced in 2.05 for rudder have been fixed but are now introduced for aileron in 2.06 ... I guess they still need to fix something ....
24 September 2012
Software Features
higher.
