Smoothing out Futaba 10c throttle stick
  • Smoothing out Futaba 10c throttle stick
    When I bought my 10c it was the version aimed at planks and had the rivoted throttle stick. I changed the metal spring over to the smoother one but it still had the rivited feel so I sanded down the rivets on the actual plastic bit that the metal spring touches.
    It now feels as though there is friction and I put grease on to smooth out the feel of it but it soon wears off.
    Has anyone else had a good way of sorting out this issue.
    I know I may have gone the wrong way about it but any tips would be good.
    Tonight Matthew..I am going to be.. Nitroman
    Trex 600NSP
    Blade MSR
    Futaba 10C
    Very proud owner of an EGS and Platinum Gold Star
    i put heatsrink over metal tab with little lube. Wasn't perfect but not bad
      Good idea. Thank you.
      Trex 600NSP
      Blade MSR
      Futaba 10C
        Take the metal part out... flatten well in a vice then put back....
        Mark
        www.uavaerialservices.co.uk
        BNUCs - Operations certified
        CAA - Permit for Aerial Work
          Dont have the metal part at all.
          Current kit
          Evo 50
          T-rex 500FG night setup.
          T-rex 700N pro
          T-rex 450 pro
          10CP
          Frankenstarter (dynatron)
            ah...
            Mark
              Is that to make less surface of the metal bit touch the plastic?
              Trex 600NSP
              Blade MSR
              Futaba 10C
                Could do but I like to have some stiffness to the throttle as I always get nervous when flying and my hands shake.
                Trex 600NSP
                Blade MSR
                Futaba 10C
                  No if you make the metal part flat and smooth you won't feel the clicks and it keeps the stick stiff and smooth (and comments from the twisted one's now )
                  but if it isn't like the 9cap scratch that idea
                  Mark
                    I sanded off the clicks on the plastic bit which makes me think why there is so much friction now on it unless I add grease or lube etc. Just having to do it every week or so now to keep it kind of smooth.
                    Trex 600NSP
                    Blade MSR
                    Futaba 10C
                      In the box there should be a smooth plate that you have to swap with the one thats in on the plastic plate. but it goes in the other whole 180 deg from the ratchet one!!!
                      Paul.
                      TD
                      R
                        Already done that but could still feel it clicking.
                        Trex 600NSP
                        Blade MSR
                        Futaba 10C
                          Hi
                          Try bending the metal plate up a little at a time until you get the right compromise.
                          Bob
                            I did it the same way Mark did .. Flattened the metal part and bent it upwards a little then put it back and theres a little friction there but no clickiness ... nice and smooth for my throttle now
                            Knight 3D
                              Sell the 10n and get a 12... totally adjustable tension / ratchet really nice gimbles in the 12 they are ssmooth...
                              Steve
                              Steve...
                              Outrage RC Field Rep
