600n with the shakes
    The only 2 times my 600 shook that badly was, 1, when the headspeed wasn't high enough using the firmer dampers & the heli shook really badly & 2, when the blade tracking was out quite badly after a crash.
    Del
    Climb-Out
    3D Scotland
    Proud owner of 2 EGS
      back with report shakes was duff engine, it had i high pitch noise witch seem only i could here. (i hear ultra high frequencies i.e dog whistles etc) and thought it was normal.
      Well engine run beautifly but drank heavy and whilst flyin just quarter tank with main needle at just over 1.5 turns plug popped. I checked none fellin cylinder look ok so put another plug in, with main needle richend too exactly 2 turns out took off and bang engine rattling piston broken
      well other than engine being a write off I HAVE NEVER EXPERIENCED A REAR BEARING being kernackered like this only gallon and half old but hay ho
      Put a second hand engine in witch had new bearings wow so much quieter no ultr high squeel and .......... no shaking at higher rpm's
      thanks all the best terry
