The problem with the Trex 600 Pro/Dominator is that in standard trim the motor mount is fixed, so you cant change pinions. This means that you need a motor that is exactly or very close to the stock Kv (530Kv). 560 Kv may be a bit high. The 4035 designation usually refers to the size of the stator. A 4035 has a 40mm diameter x 35mm long stator so a 4025 is a significantly smaller and likely to have less torque and lower ultimate power rating.
Personally i'd not even be considering changing the motor at this point as there really isn't any evidence at all that the motor has any problem. Trouble shooting a heli problem by random chang-out of major components can get very expensive very quickly! A 'wobble' in flight wouldn't usually be down to vibration anyway. All the stuff that spins on a heli does so at high speed, so vibrations will be high frequency. A 'wobble' is usually down to a head problem, such as worn or too hard dampers, head gain too high.. or maybe notchey thrust bearing
er.... last time I had them out? err, 2 1/2 years ago just before they went in for the first time
