600 esp with new 600 FL Head set problem
Trex700e, V bar v5 pro,
Trex450v2
Trex 600esp....scorpion motor and 8s setup...hold tight....Tags: None
The guidance to use the H5506 shaft is assuming it's being installed on the newer 600e Pro or 600L Dominator frame. The ESP needs a different length shaft.
There is a list of all 550/600 Align shafts here: T-rex 10mm Main Shaft Measurements | Ron's RC Helicopter News
In your case i think you have a problem because there appears according to this list to be only two alternative shafts for the ESP, the stock shaft which is too long for the FL head, and the DFC shaft which is too short. So unless Align have recently released a new shaft that's not on the list you would have to cut down your old ESP shaft. That isn't difficult, a Dremel easily cuts the shaft and a good sharp drill will make a new hole. I cut down a shaft when I fitted a Blade 600X head to my own Trex 600, getting the length exactly right so that the radius arms are level at mid stick is a bit of a challenge, it took me a couple of cuts to get it right, best start off on the long side and trim down.Last edited by Grumpy; 28-09-2016, 07:39 AM.Goblin Kraken, SoXos Strike 7, XLPower Specter, Goblin Black Thunder T, Goblin 700 Speed, Goblin 770 Comp Carbon, Trex 700X, Kasama Dune, Henseleit TDR
I ended up using HN6118T (sad I know that from memory) which gives you the flexibility of the movable collar but short enough to use with a DFC head without it looking silly. Admittedly this has the extra 10mm on the bottom for the third bearing block which the esp didn't have so either cut this off or just leave it.
the problem though is the HN6118T shafts are becoming increasingly hard to find as spares for this older heli dry up.
My extremely modified/pimped-up old 600e beater heli's days are very much numbered im sad to say.
If it helps I can post a picture of my modifications later.
RichLast edited by Rich_H; 28-09-2016, 02:27 PM.Heli's: Align 700X, TSA Infusion 700e Platinum, Align 600e Dominator, Align 600n pro DFC, Align 450 Pro DFC Stretched
Fixed Wing: SEBART Suhkoi 50e
Gear: Futaba 14SG
Newton Abbot Heli Club: http://www.naheliclub.org.uk/
Zeal Blades UK Flight Team www.zealblades.com
Hi,Originally posted by Rich_H View PostI ended up using HN6118T (sad I know that from memory) which gives you the flexibility of the movable collar but short enough to use with a DFC head without it looking silly. Admittedly this has the extra 10mm on the bottom for the third bearing block which the esp didn't have so either cut this off or just leave it.
Rich
Can you please tell me where you bought your HN6118T main shaft from, as I need one but cannot find them anywhere on the web
DaveTREX 700 LE - Spartan Vortex
TREX 600 LE - VBAR 5.3 PRO (DFC)
TREX 600E PRO - VBAR NEO (PRO RESCUE)
TREX 550L DOMINATOR - MINI VBAR EXPRESS
BLADE 130X
DSX11
