Hey guys
i have recently built a 600l with an edge 80HV ESC and i am slowly figuring out the electric side of this hobby. Had a raptor 50 before this!
anyways, i read on a post that to use the governor mode. I read on another forum to set a straight throttle curve of say 30% (norm) 70% idle up 1 and 100 for idle up 2. 0 for throttle hold.
the writer suggested arming the ESC by powering up the heli, then moving to throttle hold (ESC sees zero) then turn off and then the motor will spool up till governor speed. All good. Thread here, post 5:
Trex 600e pro throttle curve and pitch curve setup - HeliFreak
To spool down at the end of the flight, simply flick to TH and then i guess go and bring it in to the pits. My only worry this way is you only have the safety of one switch to protect you from a spool up?
How are you guys doing this. I see the ESC comes with an aux wire for arming / disarming. Would this be wired into the gpro or direct into the receiver (futaba). Would this give 2 switches for safety?
Kr
Craig
Kr
Craig
