Good Evening all,
I'm scratching my head a bit with this not sure where to put my finger on it, the heli is a new build latest 600 dfc with the 750mx.
The tail isn't brilliant on it, it's not as good as my efl was it kicks out a bit even with revomix on the beastx on high, I never ran revo on my efl and was pretty happy but it only had the 600mx in it.
I've just been giving it a once over checking everything to make sure it's all good and noticed dust around the umbrella gears. I've pulled them out and they have worn quite a bit and it has only done 16 flights.
My gov gain is at 13 and I run a headspeed of 2300. My efl was up at 17 iirc and never wore a gear out in 100 flights until I decked it lol
I had set it all up with the govenor gain a lot lower than I usually would, it would drop headspeed at the bottom of a loop. I've brought it back up a step at a time until it holds a consistent headspeed.
The gearmesh on the dfc umbrella gears doesn't seem to be any different to what my efl was, it's loose now they're worn but was good when built.
Is it something I'm going to have to live with running a bigger motor or are the black gears weaker, or do I need to change some things? I've got spare gears so that's no prob.
Ta
Ta
